W
whitty915
I have a 2009 Nytro XTX with 5K miles on it. When i turn the skies all the way hard left (only to the left) the yellow engine light comes on and the sled goes into limp mode and wont move. as soon as i put the skies straight it comes out of it and is fine. Any ideas? Could it be pinching somthing, gas line, sensor??
Thanks for any help and happy new year!
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
What's been done to the sled lately? Relocator or riser? Sounds like your TOR's is trying to tell you something. Check throttle cable routing and condition.
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 12 Nytro XTX (mine)
06 Apex GT (wifes)
07 Phazer (#2 sons)
02 Viper (#1 Sons)
X2 TORS problem.. Throttle Overide System.
W
whitty915
thanks guys, i will have my dealer look there first. Appreciate the advice!
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
Do you have a riser or relocator on it? Like others before said it must be pulling on your cable. Check the adjustment on it or possibly reroute the cable if need be. Does it flash code 84 as well?
TORS... throttle cable is too tight.
TORS. Happened to me after doing OFT relocator. Did some adjusting, been fine ever since.
Pstn head
It's TORS for sure adjust your throttle cable free plat and make sure the cable is in good shape and not coming apart anywhere.
Pstn head
I meant to say throttle free play... Damm spell check.
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
Has anyone mentioned TORS? Might be TORS!
...all kidding aside I put my hand guards back on my sled and I was getting the old code 84 the other night. By changing my thumb position on the throttle I was able to get it to stop but I'm going to have in investigate what is going on.
canoehead
- Jan 14, 2011
- NE, Alberta
Could possibly, just maybe, slight chance it's ..........wait for it...........TORS?revster said:Has anyone mentioned TORS? Might be TORS!
ryan_p17
double check that the jam nut hasnt come loose on the throttle cable at the throttle body. this will cause free movement of the elbow on the cable and cause the same issue. you can see if from the clutch side of the sled.
