Apex18
Ok, so i have a 07 Apex RTX snowchecked. I would just like to know how it is geared compared to last years RTX. And if this gearing will affect top speed by alot. If it really affects top speed, i might change it so its like last years RTX, so will this be easy?
Also, how is the engine positioned on the Apex. I heard it is set farther back but i am not sure. I'm just curious how heavy the front end will be.
thanks for the info!
welterracer
it has a 22 top gear instead of the 24.. Im not sure but the bottom grear might be different too..
It will loose about 2mph on top end (on snow) but will be alot more fun corner to corner and lowend and midrange!
the apex engine is tilted back farther than the rx-1 but is no different than the 06 model..
