Vonklem
- Jan 7, 2010
I'm new to snowmobiling and am looking for some advice from experienced members. I live in Oregon and will be riding in heavy wet snow off the trails. I am a snowboarder looking access the backcountry. I know i need a long track, but do I get a two or four stroke? I have been told four strokes have a hard time in deep snow off the trails. Slow throttle response and less horse power per cc than a two stroke. Anyone ridden both two and four stroke in deep wet snow? Can you give me a pros and cons of both?
TrailxRider
I don't ride off trail but generally speaking 4 stroke sleds are a little heavier than 2 strokes due to larger engines. 4 Strokes have more torque and 4 stroke engines are more reliable than 2 stroke engines.
With the proper setup even with the 4 stroke off trail, it will be a great sled. I'm sure you'll get better answeres from other members who use their sleds the same that you'll be intended to use yours.
peterdb
according to your post you said you just want to 'access' the backcountry.....i view that as you are looking for a sled more as a way to get from point A to point B, rather than a high performance hill climbing deep pow sled. if thats the case get a little phazer mtx. you get 4 stroke (yamaha) reliability, light weight, and a mini torque montser all in one!
morrisond
I actually prefer 4 strokes off trail as there far superior low end torque allows you to be a lot more surgical. A two stroke in deep snow is all or nothing, with a 4 stroke you can slow down more and still accelerate.
The throttle response of 4 stroke Yammies(especially the Nytro) is incredible, will really get you up out of a hole in the deep stuff when you pin it.
The extra torque of the 4 stroke as well will be better in the deep snow.
If your concerned about weight just get a 4 stroke with a longer track and wider skis(162" 4 stroke vs. 153 2 stroke), your surface pressure will be the same and engine will work a lot better off trail.
Plus if you are in the back country, you don't want to be having to push a 2 stroke too it's limit and having it fail on you. Deep wet snow and 2 strokes don't mix.
4 strokes have a much higher MTBF - Mean time before failure.
A Nytro XTX or Mountain would be awesome off trail ( I don't think the Phazer has enough power). I would suggest the Ski-Doo 4 stroke as well but they don't make one with a track longer than 137"
If you are riding in really deep powder a lot (Mountains) get the Nytro Mountain 153 or 162, Otherwise get the Nytro XTX and put a 1.75" track on it, it will still be a great trail machine.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
I'll 2nd this.peterdb said:according to your post you said you just want to 'access' the backcountry.....i view that as you are looking for a sled more as a way to get from point A to point B, rather than a high performance hill climbing deep pow sled. if thats the case get a little phazer mtx. you get 4 stroke (yamaha) reliability, light weight, and a mini torque montser all in one!
twomorestrokes
If you are mainly off trail, stay as light as you can. A Vector or Apex type sled is a lot of sled to muscle around and try to keep "afloat" with it's front end weight. Personally, if I stayed off trail all the time and the snow was fluffy, I'd stay with a two stroke to keep from wearing myself out and keep it up on top. I still own a couple two strokes and there is still a definite niche for them but I sure like the 4 stroke sleds better for all around use.
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
i looked at the title to this post and i said to myself "self, i bet the OP only has 1 post under his name". How do I do it?
