quadtrac
Took my 08 nytro out today and it was running great at about 6lbs boost. Then I let it idle for a few minutes and all the sudden it sounded like it was missing on one cylinder, and then I seen it was flashing engine code 35. I was running 50/50 avgas in it at the time. I tried to drive it around to see if it would clean out and once in awhile it would run fine. But now it I cant get it to run any better. Any Ideas? Thanks Guys!
lakercr
Tech Advisor
quadtrac said:Took my 08 nytro out today and it was running great at about 6lbs boost. Then I let it idle for a few minutes and all the sudden it sounded like it was missing on one cylinder, and then I seen it was flashing engine code 35. I was running 50/50 avgas in it at the time. I tried to drive it around to see if it would clean out and once in awhile it would run fine. But now it I cant get it to run any better. Any Ideas? Thanks Guys!
Check the plug, cap and connection on your #3 cylinder.
