TrailxRider
This is my first sled and I'm possibly looking into the Ulmer clutch kit. I've never installed anything like this. Is it straight forward with step by step instructions or is this something I need someone to install for me?
NY AttakGT
Not hard to do at all, if you have basic mechanical ability I am sure the instructions will be self-explanitory and if not, Ulmer has top-notch tech/customer service.
You will need primary clutch removal tools (a clutch holder and a clutch puller).
--Steve (O.C.)
--Steve (O.C.)
blue er
I put ulmers clutch kit in took no time at all and well worth it
4strokelover87
blue er said:I put ulmers clutch kit in took no time at all and well worth it
X2....and WITHOUT pulling the primary off.....
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I believe there is step by step instructions with pictures on Ulmers website on how to do this.
An easy and very beneficial mod.
Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
You don't need a puller or clutch holder. Just some basic hand tools. Very easy install. Just don't drop a bolt behind the engine as I did. 20 minute job turned into 2 hours trying to get the bolt back.....doh!!!
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
shop vac and a piece of hose works to get those out.Phazernut said:You don't need a puller or clutch holder. Just some basic hand tools. Very easy install. Just don't drop a bolt behind the engine as I did. 20 minute job turned into 2 hours trying to get the bolt back.....doh!!!
Len Todd
I have a magnet on the telescoping rod. It gert right down in there, even where you can not see.
Phazernut
- Nov 2, 2007
- 04 Viper ER.
96 V-Max 4
Len Todd said:I have a magnet on the telescoping rod. It gert right down in there, even where you can not see.
Thats what I used when I finally found where it went. Its amazing where one of those little bolts will bounce.
TrailxRider
Thanks for all the replies
I ordered the Ulmer Stage 2 clutch kit. I haven't heard back from ulmer yet but I amagine they are very busy with it getting closer to snowfall. Sooner or later I
ll get it installed
I ordered the Ulmer Stage 2 clutch kit. I haven't heard back from ulmer yet but I amagine they are very busy with it getting closer to snowfall. Sooner or later Ill get it installed
peterdb
- Nov 17, 2008
- Grayslake, IL
- www.hellodave.com
TrailxRider said:Thanks for all the repliesI ordered the Ulmer Stage 2 clutch kit. I haven't heard back from ulmer yet but I amagine they are very busy with it getting closer to snowfall. Sooner or later I
ll get it installed![]()
have you had a chance to try this and give an honest unbiased review of Ulmers kit? i'm thinking about this kit too. would love to hear your feedback.
thanks
TrailxRider
peterdb said:TrailxRider said:Thanks for all the repliesI ordered the Ulmer Stage 2 clutch kit. I haven't heard back from ulmer yet but I amagine they are very busy with it getting closer to snowfall. Sooner or later I
thanks
I have it installed and took it around the yard a few times but not enough for a review just yet. Need more snow where I live still. I did notice a different with the sled running on a stand, so I'm anxious to try it out. Sled seamed to shift much quicker than before.
I'm currently having issues with my pilot jets. They keep plugging after a while. I should have ran the sled more during the summer and really regret it now. I know some people say its bad but I did it 2 seasons before and no issues at all and the only time I don't do it I have issues with the carbs and I use seafoam also.
Anxious to ride!
Len Todd
Keep those carbs wet and use plenty of Sta-bil. This last year was the only time in 30 years that I did not do that and this year I had to clean the carbs three times, so far.
how much does the kit cost?
Len Todd
