Under tunell exhaust?
I did a search too, couldn't come up with anything but this:
Excell Mountain Lite Exhaust Apex/Rx1 Mountain Complete Exhaust System
weighs 6lbs 304 Stainless Steel Body 2 1/4 Stainless 0.060 Core
$499.99
It mounts in the front holes from the stock exhaust and exits the exhaust down the hole in the rear bulkhead so it will fit on all RX, RS and Apex sleds.
Thanks buddy, now I don't have to search anymore, this exhaust looks to be what I'm going with, only change will be redirecting the exhaust out the back on top of tunnel, not down under (hahaha :-)
that's the same as I found, and if you say it will fit than it probably will...why do you want to direct it over instead of under? I want mine under so I can haul fuel and stuff on the back of the sled...
Ps, I'll shoot you a pm, I need some parts....
Bull
I want to run it out on top of the tunnel because of back pressure created in the tunnel by the track, high speed matters to me, you know 135+ MPH on the lake, backpressure will hurt top end performance, that's Y :-)
On a mountain sled it doesn't matter, cause you will not see the speeds where the under tunnel pressure becomes a problem. Climbing takes some fuel, you'll need the space to rack up some fuel more than I do.
Talk to you later
That's what Ted Jannetty and other high speed guys told years ago, I dunno how much loss there would be, but I don't care about finding it out hahaha
