Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I have the Hurricane 240 flash with after market BOV .
If I add the SS upgrade , do I need to do anything else ?
Looking for the easiest , least expensive , corner to corner pick me up .
Anyone done this ?
What is your assessment of the improvement .
Anyone done this ?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I would think you'd need the 3bar upgrade. Maybe not if your staying with the 240 SS tune.
Matt Moak
- Aug 16, 2015
- Ingleside
- 2017 Yamaha sidewinder ltx.
I updated to the 240ss and had to add 3 bar map sensor. I would recommend updating won’t regret it.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
May as well bump it to 270 while you are at itI have the Hurricane 240 flash with after market BOV .
Anyone done this ?
Mototown
- Sep 11, 2018
- Apex 40 th
You might not need a 3 bar with under 15 psig with 240 , but see how much the 270 flash is over the ss upgrade. The 270 flash is probably what you are looking for , it's a lot better all the way through.
Janne339
- Oct 31, 2015
- Sweden
- Sweden
- 2021 Sidewinder LTX GT
What are they doing in the SS tune? Wastegate duty-cycle, ignition timing?
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I flashed 2 Thundercats this year with the 240ss tune. Both needed and got 3 bar map sensors.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
I don't think you'll notice much of a difference in upgrading the tune, except making your pocket lighter.
RAMSOMAIR
WRONGOI don't think you'll notice much of a difference in upgrading the tune, except making your pocket lighter.
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
WRONGO
I had the old tune bundle, now I have the ss, and I didnt notice much differnce, or any difference really.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
I notice a difference between the SS and non SS. Actually very noticeable
no1b4me
- Dec 31, 2016
- 2019 ZR9000 Ltd iACT
Hmmmmmm.......who flashed your SS tune upgrade ?
Janne339
- Oct 31, 2015
- Sweden
- Sweden
Closed wastegate and no leaking BOV? What else can you do to spool faster? New header? Or heat from fuel and changed ignition timing??
Let me know!
Let me know!
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
me. I have the bundle and flasher. Ss tunes need 3 bar map sensor too, so it’s impossible that’s it’s flashed incorrectly.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I ran both 270sm and 270ss back to back on my sled and could say by my a$$ dyno that ss pick up faster down low!
