upper A Arm bolt bushing loose
Terrace BC
was riding this weekend in some nice bc pow and noticed when i got stuck with the right ski up outta the snow that the upper a arm inner bushings or bolt is extremly loose. :yam:
just wondering if the upper insert bushing/bearing is replaceable or if im lucky have you ever seen the bolt loosen off?.
im a little leary that my faith in yamaha and my no excistence pre trip check along with some hard rides might of took out the upper a arm ( by oblounging the bushing insert area).. :bling
any of you ever replace the a arm... beacuse of this.
ive already got the warranty bj done, and looks like its do again. #$%&*
There was a recall for the upper right A arm bolt coming loose...did you have this recall?
At the very least, check it out and tighten it.
It is a update and should be taken care of asap. What you need to do is remove the bolt and locktite it with red loctite. If it were mine i wold do it to both sides.
It only happened to a certain number during assembly so call and check with your dealer and they can let you know if it applies to others and will do the work for free! It was a 09-10 sled issue, not 08.
