Upper Ball Joint Machining??
So if I understand correctly, remove ball joint, and have 2 -2.5mm of the material next to the threaded shaft removed to create negative camber, which should give better cornering. Have people been doing this on the MTX model as well?
Yup it's that simple. Can't see why it would help on the MTX but maybe post over there.
You can't see why it would help or why it wouldn't?
The MTX pushes hard in the corners, hoping this may help.
I'll ask over there.
Sorry, meant to say "wouldn't". I'd give it a go plus maybe some more weight on the front skis.
