Upper ball joint cut question??
glmf
Maine
Can someone tell me either the dimension of a cut upper or a stock upper ball joint on the 08Nytro. I took my sled to the dealer and they replaced the lowers under the service bulletin and I think they did the uppers too. My old uppers had the 2.5mm cut and I had the sled dialed in perfect. Now the sled has a little of that twitchness back and I think the uppers have been replaced. I have checked toe and thats good. Don't want to cut 2.5 off again if it is in fact my old ones, so if someone could give me the measurement from say bolt hole edge to machined face of either stock or modded upper ball joint, I should be able to tell which one I have. Thanks much
before anybody runs out and measures the ball joint, I figured it out when I took one apart. It was easy to tell I had cut these. Now to figure out why when the lowers were replace, a little twitchyness came back,,,things that make you go hmmmmmmmmmm
