jsjk-4-stroke
took out o5 mono suspension to grease everything and replace all plactic
bushings & 1 bearing upper rear wheels have 2 spacers , one is larger od
did not watch how they were in place.
need to know how they go back in , is it large o.d spacer then the wheel
then smaller spacer then plactic
thanks
thanks
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Goto "Yamaha Parts Finder" at the top of this page and follow the drop down menus to get to the microfiche diagrams of your sled.
You should be able to find the said spacers that you are asking about. Very helpful those diagrams are.
Good luck.
Good luck.
jsjk-4-stroke
i went to parts finder they show the 2 spacers but not the wheel
or if the wheel goes between them , i dont know
thanks
thanks
Len Todd
The expolded view figure is "Suspension 2" of the 05 Rx-1 figures.
Click here for Yamaha Exploded View Drawings
It looks to me like the wheel on figure "Suspension 1", goes in between the two washers Item #s 30 & 31 on figure "Suspension 2."
I think the question is: Which part you have in hand is #30 and which is #31. There apparently is a difference. The Item Descriptions do not help. Maybe is is time for a trip to dealer and measure what they have for part 30 or 31. Then put them back in like the diagram, #30 on the inside and #31 on the outside of the wheel.
Oak Hill
- Dec 19, 2004
- Owosso, Mi
- www.airtoolexpress.com
The larger washer (bigger diameter) goes against the bushing, then the wheel, then the smaller washer and finally the plactic spacer!
Len Todd
Good Job Oak Hill!
I knew someone with experience would come along sooner or later! The figures only go so far!
