WildBill67
- Feb 13, 2020
- MA
- 2007 Yamaha Apex
Hi guys,
I recently bought a 2018 Sidewinder LTX LE with a Turbo Dynamics 2 stage kit installed and I want to change the oil and I was wondering if I should stick with 0W-40 or something else?
Quality 0W40 full synthetic will be good to go.
WildBill67
- Feb 13, 2020
- MA
- 2007 Yamaha Apex
Do you know if the recommended is 0W-40 like the internet says or 0W-30 like the manual says?Quality 0W40 full synthetic will be good to go.
I use 0W30 in my SW but all my riding friends with 998s use 0W40. Both grades are fine and have not created any issues in our group.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
The first number is the base weight of the oil, the second number is the performance of the oil at higher temperatures. This is accomplished by adding viscosity improvers. A 30w oil is already a thick oil for a performance motor. Either oil will work. If you want the extra protection, go with 0W40.
WildBill67
- Feb 13, 2020
- MA
- 2007 Yamaha Apex
thanks guys
Pstn head
0-30 is recommended, most likely no damage useing other oil’s shouldn’t cause issues
Turboflash
- Mar 18, 2019
- Southern MN
Back in 2017, Cat recommended 0w-40.
Either is fine. Thousands of 998s out there running both.
Here in TY. There's multiple threads on oil. Just search to read.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I have been running 5w-30 Mobil 1 for a few years now on my TD tuned 2017. It has been posted here before that 5w-30 actually showed more HP that 0w-40 (30-weight vs 40-weight). Regardless, either weight oil will be fine for this application.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
QS 5w-30 for me as wellI have been running 5w-30 Mobil 1 for a few years now on my TD tuned 2017. It has been posted here before that 5w-30 actually showed more HP that 0w-40 (30-weight vs 40-weight). Regardless, either weight oil will be fine for this application.
Turboflash
- Mar 18, 2019
- Southern MN
Why do you think NASCAR cars run like 0w-20 or 0w-15 in qualifying? Less drag from oil = more hp available to wheels! It won't work for a race, but it will live just for qualifying.
