SIMMER
How's this for a cheap, removable, non-permanent solution
Serioulsy though guys....I will be clamping my hoses for our trip next week as I will proabably not have time to get around to getting the shutoff valves ordered and installed. I will probably use something similar to this.... :wink: :wink:
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
That should work fine as long as the hose regains its form. I would hate to lose performance due to fuel starvation :x
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
Recieved my inline fuel shutoffs from JR Graham today! They look like a quality valve and they where $8. a piece. But don't order the hose clamps from them! The ones I ordered, (wire type) are too small :roll: And the worm drive type would work, but there a little too big
And the type that are similar to the OEM are not available :evil:
I'm going to buy the clamps locally! :lol:
rx-1 blue reverse
Use small wire zip ties to hold the hoses on.
black john
shut off
there is ashut off built in to the full pumps but all it takes is a small pcs of ice or vaninsh and they will not work
boneman
Mighty I also saw the shutoffs in Dennis Kirk a couple thoughts
1) If it takes 2 per sled that puts you at 600cc witch our sleds get better MPG than so flow should not be an issue?
2) Do you think that may be a typo and should read for over 300cc?
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
boneman said:2) Do you think that may be a typo and should read for over 300cc?
I was thinking the same thing.
Snorover
- Apr 15, 2003
- Kittery/Fayette,Maine
- 2017 Viper
The Yamaha "Universal shut-off valve" SMA-VALVE-00-00 looks like the same one in Dennis Kirk , page 295, Universal shut-off valve #18-602.
Yamaha just say's for 1/4" fuel line, nothing about capacity.
I just installed two on my RX-1 and will check it out Friday when I head NORTH to Jackman.
1/4 or 5/16 valves work, even for the coolant...
treewhacker
If you get fuel leaking into the motor, it means you have faulty needle and seat in the carbs. That's the job they are designed to do. Sounds to me like Yamaha should eat the problem and any motors destroyed because of it.
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
Treewhacker when trailering a vehicle and accelerating or stopping the fuel in the bowl all rushes in one direction and allows fuel to manually get through the jets into the engine. Then the needle and seat allow the bowl to get refilled. After many miles trailering this can be a problem. Hope this helps clear up the need for shut-off valves when trailering.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
Makes sense Kevin, thanks.
Bob Miller
- Apr 19, 2003
- New Milford CT
So then is it a good idea after installing the shutoffs, to turn them off, run the engine until it stalls as a result of fuel starvation, and then trailer?
Port-Parts
TY Advertiser
- Sep 18, 2003
- 2012 Nytro RTX
IMO the amount of fuel left in the bowls and lines is not enough to cause any major issue if left intact. Therefore I don't think running it empty would be necessary as only a slight amount of what would be left in the bowls could actually get into the engine if the valves were shut-off.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
I agree. You also don't want to try and start this engine with dry carburators everytime you trailer. I found out how long it takes to re-start after emptying my float bowls when I rejetted :shock:
- 8K
