mdkuni
Anyone have any ideas on how to improve my steering. I have an 06 Apex and use Project X skis. They have way to much front ski pressure as the wear bar wears down in the front and the studs break off in the front. I will shim them this year but I am afraid to as I know this will make them even harder to turn. I run 6" carbides and do not have studs. Should I switch to 4"?
If you are at a slow speed, like making a turn you really need to reef on the bars to get them to go.
Transfer is set just a bit over standard towards max. Limiter strap is stock setting. Revalved shock in the rear. Front shocks are loosened to a slighty longer spring length.
