crazzy canuck
- Jan 8, 2012
Hi i recently installed a mcx 200 turbo kit on a 2012 apex and with the help from the forum ironed out an oil pump return problem. Thanks again !!! But a new question is has anyone inatslled a boost gauge on this setup ? I was thinking of splicing into the vacumn line to the blow off valve, not sure if this is the correct vacumn line or not ..... any suggestions will be greatly appreciated. Thanks Jeff
My boost gauge is teed into the 2 lines that come from both sides of the throttle body. Then one line goes to the boost gauge and the other goes to the blow off valve.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
Tee into the line that goes to the mcx fuel control box !!( Aluminium box )
crazzy canuck
- Jan 8, 2012
good enough ..... control box it is !!! thanks
