charger0926
- Sep 3, 2008
- Elk Grove, CA
- 2012 nitro mtx 162
i installed a boost gauge on my 2012 nytro mtx 162 with a mpi stage 1 supercharger. where is the best place to tap into for the gauges line. blow off valve?
thanks for any info.
shawnmcgr
charger0926 said:i installed a boost gauge on my 2012 nytro mtx 162 with a mpi stage 1 supercharger. where is the best place to tap into for the gauges line. blow off valve?
I've got a tee off of the boost sense line going to my GEMS box. That way I see what the box is seeing (before of the throttle bodies).
YamerHammer
^^^^^If you do it that way your sled will always read boost......you should try and tee from a line behind the throttle plates so you get a boost reading of what the lbs the engine is getting.
Always behind the throttle plates.
charger0926
- Sep 3, 2008
- Elk Grove, CA
so can i plumb in the boost gauge in to one of the two lines going/coming from the blow off valve. there is a upper and a lower hose coming off the bov. which one do i use. i cant see which line goes back to the throttle bodies.
