blown apex
- Jan 29, 2006
- ALTON ILL.
- ristermotorsports.com
i have a 06 apex with 18000 miles
after running it for and hr or longer come to a stop
and it dies.
when you go to crank it the starter sounds weird like its skipping
a beat
give it gas startes up and runs good for another hour or so
has anyone seen the exhaust valves tighten up
ive got the valve cover off and one cyl is a tight .004
the rest of them seem to be a loose .004-.005 exhaust
intakes are a loose .004
ive already turned the idle up with the knob and
the 4 little adjuster screws (air screw = out )
any suggestions thanks
and it dies.
a beat
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Don't know how .004 thousands can be both tight and loose! I'm also not sure how the problem is valve related! Almost sounds fuel related. Maybe try turning the air screws in!
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I have seen some high mileage Apexs do this and have yet to find the issue. I also have not checked the valves on it yet.
09nytro
It has fuel injection so if you are turning any screws then you have the throttle body's all out , so now you will have to get some gauges and tune them back in , it also ( from what you are saying ) sounds like your starter is going bad as well ....
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
check your battery is it possible for timming to be off?
Did you check to see if your belt is tight?
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Starter is an easy swap, and very probable at that many miles. Check the thread on the CO adjustment for Apexes. Many of us with "moderate" miled Apexes experienced the stall when coming to a stop and fixed it with a CO adjustment.
Good luck,
Good luck,
VMX
- Nov 9, 2003
- Ma.
- 2006 GT ,2007 RTX, 2011se
if you have the cover off check the cam timing mine skipped a tooth and was doing the same thingi have a 06 apex with 18000 miles
and it dies.
a beat
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Usually the valve problems on high mileage sleds effect cold start-ups. Usually, but not always
yama_rider
- Sep 15, 2014
- New Brunswick
- 2009 RS Venture
I have the same issue with my Attak and lots of guys on here do. If I try to start it right away after the stall, it cranks a lot slower than usual....give it 5 seconds and it will roll over normally. Very strange, I know. As already mentioned, adjusting the CO numbers helped me some but not a complete cure. Since it cranks over slowly directly after the stall, it almost seems like a weak battery issue, so I will be installing a new battery for this season. The machine works great other than this issue. Mine has 11.5k miles on it.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
My friend has(had) one with the same mileage that did the same thing. I wonder if a valve adjustment is in order.
yama_rider
- Sep 15, 2014
- New Brunswick
- 2009 RS Venture
My ape is random, it doesn't do it all the time. Plus I have never heard tell of this type of problem with high mileage RX1's so it seems more of an electrical issue to me. It is frustrating having an EFI sled that does this!!!
