iahacker
2011 Apex XTX with 14,000 miles and well cared for and runs fine:
Reading posts about checking valve clearances I decided it would be a good idea to check mine considering the mileage. The manual I have for 2006 to 2010.
Are the adjustment instructions and clearance specs the same for 2011 and up as for older models? I know the heads were changed from previous years.
If the clearance specs are the same, all my exhaust valves are in the middle of the range and all the intake valves are middle to lower end of the spec range. So, don't think I'll change any of the adjuster at this point.
Also, I removed the cam position sensor from the valve cover to allow more room to get the valve cover off. When I pulled it out of the hole it sounded like something fell inside the valve cover. Anyone know anything about that? I've looked all over inside the head with a light, mirror and a magnet and didn't find anything.
Any experienced help appreciated.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
I believe the heads are the same on ‘06-10 sleds vs ‘11+, but the cam timing is different, as well as the ignition timing, hence the need to run 91 octane fuel. The valve lash specs should be identical. Can’t really help you with the cam sensor question, been a few years since I’ve been into one that deep.
not seeing it in the 11+ manual but it does say to rerefer back to the rx and older apex manuals for some items.
at 20000 mi on my 11 and have not had any starting/running issues that where not my fault.
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
My 2011 has 33000 km and my dealer told me not to bother doing the valves yet. He said wait until it gets over 40000 km. He said he just be taking my money.
iahacker
This is a question from a couple years ago.
I did pull the valve cover and checked all valve clearance at 16,000 miles. Made some very minor shim adjustments just because I had it apart and wanted it perfect while I was already there.
Wasn't worth taking it apart at that mileage if it's any help to others.
NLP_SLED_GUY
- Sep 14, 2021
- Northern Lower Michigan
- 2019 SkiDoo GT-L 600R
2005 RS Rage
2003 RX1
1980 Arctic Cat Panther
My experience with bikes is that if it ain't making any noise there's no reason to do it.
Apex2007se
- Feb 3, 2020
- Hamiota
- Apex
2007 apex at 22000km did the valves 2 exhaust were out of tolerance, and the rest were just in so did all valves except 2. Shims were about $10 got a great deal. Took about 3 hours. Shouldn’t have to do again. Apex like a diesel, cheap to run but high cost to maintain.
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
Any 150-160 HP modern 2-stroke would have needed two top-end kits and a crank rebuild by 22000km. I don’t think an Ape is expensive to maintain at all in comparison, I’ve had four of them now.2007 apex at 22000km did the valves 2 exhaust were out of tolerance, and the rest were just in so did all valves except 2. Shims were about $10 got a great deal. Took about 3 hours. Shouldn’t have to do again. Apex like a diesel, cheap to run but high cost to maintain.
Hunter7
- Dec 29, 2022
- Winnipeg, Manitoba
- 2011 Yamaha Apex xtx
One of the guys we ride with is a 2 stroke Polaris guy, keeps blowing motors up.
