healter skelter
I am running the heavy springs for higher boost and now the intake valves are cupped, has any one run into this. Is there a better valve that guys are using now
ultimate
- May 14, 2005
- ,Quebec
- uniklabels.com
- Yamaha apex
how much boost do you speak?
healter skelter
I was running 19 lbs, plan on running more though
ultimate
- May 14, 2005
- ,Quebec
- uniklabels.com
- Yamaha apex
so,you can run easily with stock springs valves!
good about 380hp...........!
TWIN TURBO
- Aug 30, 2005
- Chicago IL.
- www.powerbygns.com
Stock Apex valve springs that is!
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
Heavy valve springs will not tulip valves
BUT
TOOOOO MUCH COMBUSTION TEMP WILL !
heavier springs are only needed for extra RPM !
BUT
