mitsu blow off valve
Need for Speed 2
Nova Scotia
Hey guys just had to share this little uereka thing I found. If you are running the mitsubishi blow off valve wich most turbo s are here is a cool trick that worked great for me. take the valve apart from the tank gently pull the plastic halves apart there is a spring that is quite stiff you want to remove it . Holley vacumm secondary carb springs fit in there almost perfect. you can buy an assortment from say TAP. I put 2 springs in mine together very soft responds to vaccum very sensitive turns that valve into a very good bypass. I feel its better than the vortech as far as sensitivity and it costs like 25 dollars. worked awsome for me. Ted you inspired me to create this cure for my problem, Thanks buddy
Great info. All MCXpress kits come with the little Mitsubishi BOV :-). Can I run both the Vortech and the modded Mitsu?
You sure can it will work great I run 2 vortechs and one modified mitsu bloe off on a stage 2b super charger. The little trick with the mitsu I had to share I was so impressed with my trial and error some things flip some things flop. Also to all you fellow TYers Merry Xmas and a safe an d long riding season. Cheers
Thanks, merry x-mas, LaLaLa
:drink: :drink: :drink: :beer:
