rough rider
Has anyone ever removed the stub crankshaft assy where the clutch bolts on to, it looks like it it bolted to case with 4 bolts, is it possible to unbolt and pull out of engine case, I am having some spline wear issues with mine.
Len Todd
You might want to try posting this in the RS or Engine Forum. I would bet you get more and better answers.
I am not well versed in Vector stuff. Otherwise, I would try to give you some help here.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
I don't know anyone that ever pulled these motors apart....Maybe in the NOS or Boost section where someone might have blown up but these motors rarely come apart unless someone is doing porting work and or rods, etc.
Mountaintech
rough rider said:Has anyone ever removed the stub crankshaft assy where the clutch bolts on to, it looks like it it bolted to case with 4 bolts, is it possible to unbolt and pull out of engine case, I am having some spline wear issues with mine.![]()
PM Powderlites. His name is Dave and he is very familiar with those engines.
- 8K
