You can look up what you need in the TY Tech section for specifications for the sleds that you mention. I believe the basic primary and secondary clutches are the same, but weights, springs and helixes will be different between the 3 and 4 cylinders.
Looking at the part numbers, there are some fairly major parts that are different... Sheaves are the same, spider is different... Doesn't mean it won't work, as long as the shaft diameter/taper is the same it can be made to work!
