Vector pilot jets?
How hard is it to get to the pilot jets for cleaning? Ran great last season but coming out of storage it won't idle. The choke needs to be about half closed to idle and it really stumbles to the R's up. I tried Sea Foam, no luck.
:o|
Not hard to do. On my 2008, all I had to do was remove the airbox, then pull the carbs out of the intake flanges so I could tilt the carbs up a bit, then remove the float bowls. The pilots come right out with a flathead screwdriver. You don't have the remove the throttle cable or anything like that.
:o|
