Britton Evans
- Dec 15, 2016
- Santa Fe Ski Company
- 2007 Phazer RTX. 2009 RS Viking Pro 2014 Venture etc...
Having a simular issue with a 07 Viking Professional. Unit empties the bowls on the carbs when loaded and going up hill. Have heard this happens with the vikings at other ski resorts. Has anyone thought about putting a low pressure high volume electric fuel pump on these. Have gone through the filters in the tank. and have replaced the fuel lines outside the tank to the pumps. Will test the two small vacuum lines from the carbs to the pumps. We have new pumps on order from another mechanic. Don't think thats the issue yet.
Metallicat
My problem ended being the fuel pumps. Replaced them both now it runs fine.
I changed the fuel filters this evening. That was easy, about 15 minutes to change both. Old filters looked ok. Vacuum lines and fuel lines looked good. So I pulled the carbs again and removes the float assemblies. The needle valves looked great. Two of the floats were out of spec so I adjusted them. They were 1-2mm too high @ 17-18mm. They are all even now at 16mm or close to it. We shall see how it runs now.
I looked at the fich today for the 2 filters that are supposed to be in the gas tank & it does not show them. Where is there a picture of them.
Britton Evans
- Dec 15, 2016
http://www.yamahapartshouse.com/oemparts/a/yam/5003c5f4f8700212fc842a85/fuel-tank
Took my own pic, just have to figure how to post it.
Britton Evans
- Dec 15, 2016
I see the filters listed on the 08 Viking but not on a 2011 Vector. Since my 2011 Vector is fuel injected is that why there are no fuel filters listed/
Britton Evans
- Dec 15, 2016
Injected system would likely mean an internal tank fuel pump and thus a sock filter on the pump. Not sure. But as I work on Yamaha more and more my thoughts are that you might just be correct.
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
Nothing wrong with that!Notice my poor man's hose clamp made from SS safety wire...
Redbeard
- Oct 14, 2011
- IN
Did you take pictures of the screens by chance? You have the 973cc carb Vector, correct?There is indeed a fine mesh screen under the float valves. They are barely visible.
Also, what year is your sled and how many miles when the fuel pumps went bad? I'm just making mental notes for my 2008 Vector. It has 9000 miles so far.
Metallicat
I took no pictures. My sled had close to 10,000 miles on it before I experienced the problem. 2008 Vector with the carbed 973. I wonder if storing with Seafoam contributed to the problem.Did you take pictures of the screens by chance? You have the 973cc carb Vector, correct?
