Rash
OK, i got a Apex LTX and had an ATTAK before.. .Bought a Vector LTX for my wife, but i tried it, seems pretty vibrating at low and medium speed, like if some rubbing was going on in the track...
euh...
showd it at the dealer, said it was normal..
i'm wondering, i'm not used to vectors at all..
are they really that much more vibrators than the apex's??..
thanks for your input..
RASH
euh...
RASH
Rash
It's like a buzz in the hands after 20 min they go a little numb.. or would that be the total laque of heat??
pat the rat
- Mar 13, 2006
its normal,mine is like that too,you get used to it after a while,worst when your in loose snow
Rash
OH.. MAYBE ...
is the 2010 FI better??... cause after 2 years on the Apex... i'm sort of used to SMOOOOOOOOOOTH...
And i don't remember the Nytro being like that..
oldslowsledder
Wifes got an 08 Vector, can't honestly say it has your issue.
Rash
OK.. part of the vibration was the rails in front, tightening the strap one hole and is 60% better... but clearance from the tunnel for the ripsaw track is 1/4 inch.. so i think when rolling, the track probably rubs everywhere along the aluminium protectors under the tunnel ...
:exc:
:exc:
swmichvector
- Jan 27, 2009
- Clare, Michigan
- 2011 NYTRO
must be yours, mine is not like that
Rash
Mine is a 2008.. but i think it is pretty normal..
will see when i go get it tomorrow..
:exc:
:exc:
mtkaboater
Better check the pivot arm in the rear skid. A well documented problem for 05 and 06.... If yours is cracking then maybe causing your skid to be in the tunnel a little skewed.
