bleedyamaha
- Sep 28, 2013
- Northern Iowa
Just took out my 14 Ltx se for a quick spin in 12 inches of powder. After getting on the throttle I am feeling a vibration I have never felt before. The only things I changed from last season is I had my skid shocks revalved and added weight to my Cotc. I did re adjust my osp belt adjuster I backed it out till the secondary just barely started creeping. It feels like you feel every lug on the track when you get on the throttle. I don't think the track is spinning but the snow is real powdery. I will check for track rub when the snow melts under neath further.
New slides?
bleedyamaha
- Sep 28, 2013
- Northern Iowa
New slides?[/QUOTI will check them I have a little over 2000 miles on them
bleedyamaha
- Sep 28, 2013
- Northern Iowa
I put my sled on a lift and cranked on the throttle and didn't feel any vibration.
stingray719
Change your drive belt.
Stingray is probably right. The slides thing was something I noticed last time I put new ones on. So if yours are still good. Run them.
Robinmaine
- Apr 26, 2015
- Sabattus
- 18 SR Viper LTX
I would also go with the belt. If you had the sled running and reved it a lot the primary will groove the belt in one spot and vibrate almost feel like the track is coming apart.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Thanks guys put on 30 miles this a.m. Will try the belt next trip out. My exhaust can tail pipe broke loose this morning. Arhhhggg!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I had a vibration like you mentioned last season and it was the belt!! It was felt at my feet!
