Gone Blue
- Oct 11, 2006
- Howell, Michigan
If any of you guys are using the vinyl nose bag and storing a spare belt in there, you should check the belt if you haven't looked at it in awhile. I just popped mine off for the first time in 2 years and found that my used spare belt was cracked in 2 spots. The tight fold of the belt so it fits in the bag must have done the trick. Luckily Phazer's don't blow many belts. I have not had a belt issue in the 5,000 miles I have put on my Phazer.
I had recently realized that I could not even remove my vinyl nose bag from the sled once I added a Skinz Float plate. So I just bought an 07' tunnel box from SnoNinja to use from now on. I have extra room on the tunnel so I might as well use it and have easier access to tools and belt on the trail. G.B.
