Viper/Nytro engine
kennyspec
stonewall, manitoba
Canada
nytro
hey guys I managed to pick up a 16 viper MTX with a blown engine. He suspects crank bearings. Only 500kms on whole sled and it was turboed. Turbo kit has been removed.
To save time I was going to swap in my wife’s engine from her 08 Nytro. Then find/rebuild one for the Nytro.
Is everything the same between the Nytro/viper engine? Stator and all sensors the same? Anything I need to look out for? Figured I’d post in here as this seems to be the most tech savvy forum about the Nytro/viper
grizztracks did a similar swap in the viper section. the info you need might be there. he swapped it though to put the nitro ecu into the viper.
