Tomkat700
- Aug 20, 2014
- 2015 Viper MTX 153 T
I have a 2015 Viper MTX base with 153" track and MPI 180 turbo, my question is how do I get more lift from my front end. I want it to pick the ski's up a little more than it does now. Should I tighten or loosen my center shock? Also will letting the limiter strap out one hole help? Thanks for the help.
stingray719
Its a known issue, at least by me.
See this thread for the cheap and easy fix. http://www.ty4stroke.com/threads/interesting-skid-shock-spring-info.131147/
Tomkat700
- Aug 20, 2014
I like the feel of the steering I just want it to pick the skis up a little more. Right now they come up about 8" when I hammer it and I want to be able to get them higher for crossing creeks/dodging trees, ect.
N2DEEP
Is there more holes in your strap to lengthen it ?
Tomkat700
- Aug 20, 2014
No more holes on the limiter strap I looked last night and it is all the way out.
akvector
stiffen center shock and lighten the rear shock. you would think that turbo would stand on end on command.
Tomkat700
- Aug 20, 2014
I thought so too, I will try this and see how it works. Thanks for the help.stiffen center shock and lighten the rear shock. you would think that turbo would stand on end on command.
vroy7756
- Feb 11, 2015
- Chatham, Ontario
- 2019 SRX LE
2015 rtx-le sr viper 129" track
2010 rs ltx gt vector
take the coupling block right out light up the ski pressure
kodak
I have same issue skis will not lift anymore than 8 " my limiter strap has 3 holes on one side of stra and 2 on the other have lessened both
Tanker Yanker
- May 4, 2014
- Davidson SK
- 2015 Yamaha Viper XTX LE
2009 Yamaha Nytro RTX
My turbo XTXLE was like that also. What you need to do is move the skid, these sleds have different predrilled holes on the tunnel for the skid to mount to. At the front by the foot wells move the skid back and down to the next hole and at the back of the skid there are 3 holes move it to the middle one. Takes weight of the front of your sled and makes a huge difference. i can stand my sled straight up any time i want to now.I have same issue skis will not lift anymore than 8 " my limiter strap has 3 holes on one side of stra and 2 on the other have lessened both
kodak
Tomkat have you tried any of these recommendations with any success?
kodak
Tried the skid settings recommended in this post but having a hard time getting the track tension back to 2 inch sag did you have this trouble when you moved skid will the track loosen up on its own?
Tanker Yanker
- May 4, 2014
- Davidson SK
i run mine tighter than that. If your track is to loose the clips will rub on your skid as shown in another thread .Tried the skid settings recommended in this post but having a hard time getting the track tension back to 2 inch sag did you have this trouble when you moved skid will the track loosen up on its own?
Simoneau+
- Nov 20, 2014
- sr viper mtx 153 2015
Are you clutched right because i got the same thing and its a true wheelie machine in this video rear skid is 100% stock ....
bgk700
- Feb 22, 2015
- Viper mtx apex mtx
Had a hard time getting my 153 lighter in the skis so i cut some belting 17.5 inches long. Its 2 inches longer than the stock limiters. Now weight transfers to the rear and u can actually weight steer it now. I think 17 inch straps would be ideal. U do have to tighten the track quite snug so it dosent ratchet in the powder
