rough rider
who has installed a tether cord and if so what wires do u hook up or should i ask if there is a plug and play availible
stingray719
Question, if Viper has an engine kill on low oil pressure how important is the tether?
Bad Attitude
- Nov 21, 2005
- People's Republic of NY
- 2014 Yamaha Viper LTX SE
I got one from a cat dealer. PN#5639-860. I looked through the directions. You have to pull off the side panels and the top panel Disconnect the handlebar harness connection to the main harness. Locate the red/violet wire from the handle bar harness. Plug the red/violet into the harness connector for the tether. Then plug in the green wire from the harness connector into the handle bar wire connector block where you removed the red/violet. Plug in the tether switch. Rev\move the seat and upper/lower console. The directions give you measurements for the hole. Drill reinstall the console and seat. Plug your harness connections back together reinstall your top pod and side panels.
I used the 4strokesolutions rollover valve. Is activated with a tether and can use a button to prime the pump if it ever should lose prime.
allyammies
You need them for radar runs now.
Yes the CAT one is plug and play and I reccomend one. I rolled my sled 3 times last week and lost prime all 3. after the tether no more.
YamahaTim
- Sep 21, 2013
- Farmington, MN
- 2014 Yamaha Viper LTX SE MPI Turbo
Yamadog said:Yes the CAT one is plug and play and I reccomend one. I rolled my sled 3 times last week and lost prime all 3. after the tether no more.
Well quit rolling it over!
