Sasquatch said:
RTX Meirda said:
I hear that because of the hot summer, the lakes are really warm.
Because of this, the lakes will take longer to freeze. If the lakes are open, the wind can pick up the moisture and blizzards for everyone!
Experiment that I done in school long ago. Hot water accually freezes faster than cold.
Something sounds funny there. I think you're going to have to describe your experiment in great detail and determine that someone else can reproduce it repeatedly under a controlled (ie not your kitchen freezer because it WILL screw up the results) environment.
Water cools by releasing its energy into its environment. The higher the temperature, the more energy it has to relase. The rate of energy release is determined by conductivity and surface temperature differential.
In freezing two samples of water, one starting at 50 degrees (C) and the other starting at 20, once the 50 degree water has released enough energy to drop to 20 degrees, it is identical to the sample that started at 20 degrees, so the time it takes to freeze the 50 degree sample is exactly equal to the time it takes to freeze the 20 degree sample PLUS the time it takes to drop the initial 30 degrees from 50 to 20.
If you did this experiment in a kitchen freezer, the results will be screwed up by the fact that the temperature at any point inside the freezer is NOT CONSTANT. When the freezer warms up, the blower starts up, which can cause VERY RAPID cooling for its duration, and concentrated under the blower.
Where this hypothesis does NOT hold is where the water may be impure. Say there is something dissolved into the water... this could lower the freezing point or alter the conductivity. If this substance is evaporated when the temperature is raised, then the two samples may have different properties. Say for example you are trying this experiment on a bottle of Jack Daniels..... start one sample at room temperature, boil the other one for an hour. The one that was boiled will have a lower alcohol content and higher freezing temperature, so it may very well take less time to freeze for a particular pair of temperatures.
