Apex Man
Let's hear about your experiences with and without a blow-off valve on an MPI supercharger. I hear good and bad things about the subject so would someone chime in on this and tell us about mileage gains (or losses), throttle response (boost lag time), etc.
Thanks,
Moon
Thanks,
Moon
I did a search using keyword...BOV...and it resulted in 136 matches !!!
I did another search using author...HAMMER...and keyword...BOV...20 matches !!!
Pretty much everything you need to know has already been posted. In my opinion, to not use one at over 5lbs boost, in this SC application, is friggen retarded. Compressor surge IS a bad thing !!!
Been-There-Done-This: http://www.ty4stroke.com/viewtopic.php?t=43075
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
Apex Man said:Let's hear about your experiences with and without a blow-off valve on an MPI supercharger. I hear good and bad things about the subject so would someone chime in on this and tell us about mileage gains (or losses), throttle response (boost lag time), etc.
Thanks,
Moon
Still debating ehh Apex man.
Feel Free to give me a call and I will be happy to answer all your questions.
Ted.
Colorado Yamaha
- Sep 4, 2005
- Colorado Springs
- 2010 Nytro MTX - MCX
Ted,
Any pic's of the BOV on an RX-1? (charge tube location?). Thanks, Derek
I have pretty good room.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
Ideally you want to get it in the charge pipe from the supercharger to the intercooler or the lower intercooler tank.
I had one in here last March and it was in the Charge pipe before the intercooler, it was very tight but it fit and worked extremely well.
You should be aware that you may have to increase the size of your pilots and possibly raise you needles because you taking the pressure off the float bowls during light throttle operation.
An Innovate Wide band gauge can be priceless to get your carbs or fuel injection dialed in.
Ted.
Ted.
Otis RX
Ted Jannetty said:Ideally you want to get it in the charge pipe from the supercharger to the intercooler or the lower intercooler tank.
Ted.
Ted....we need to talk about a BOV for my sled.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
Otis RX said:Ted Jannetty said:Ideally you want to get it in the charge pipe from the supercharger to the intercooler or the lower intercooler tank.
Ted.
Ohh Yeah, The bender kits are a littel trickey because of where they source the signal for the carb bowls, just a little rejetting is required.
