RX-1 Liter
- Apr 14, 2003
- Chautauqua County, NY
- 2017 RMK 155"
I have a 2010 Nytro MTX with a 7psi MPI Blower that is leaking boost out the blow off valve under 1/3 throttle. I have the adjustment screw on the spring tightened down to one thread showing as per MPI. On the jackstand at 1/3 throttle the valve will open aprox. 1/8" and lets boost blow by. Is this normal?
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Yes it will always blow off a little boost until you get to WOT and 100% load. That is actually a good thing at that throttle position and load for your mpg.
FLYBYU
RX-1 Liter
- Apr 14, 2003
- 2017 RMK 155"
kinger said:Yes it will always blow off a little boost until you get to WOT and 100% load. That is actually a good thing at that throttle position and load for your mpg.
Thank you.
