Just bought a set of extro drivers for my 09 nytro that has the OFT 144 extention kit. Do I need to cut the rails on the regular shorty and run anti stab wheels or is this just for the XTX running the extros? Also, should I remove the outer drivers and just run the extros (is there any disadvantage to leaving them on)?
J.R.
J.R.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
You dont need to cut the rails.
toyota4runner
- Jan 23, 2012
- Manitoba
- '09 FX Nytro
What size is the drive shaft on a 09 standard nytro? I'm just about to order wahl extros and I want to make sure my callipers are right. I'm getting a hair under 1.125" or inch and an 8th. Is that right?
Supa Dexta
1 1/16th
And - Just run the extros, no need to cut rails and I dont run any anti stab.
toyota4runner
- Jan 23, 2012
- Manitoba
- '09 FX Nytro
Should I press them on dry and room temp or is anyone heating them up in water and leaving the shaft in the cold? I have a nice press but I've never installed drivers. Thanks
DV8
- Feb 9, 2010
- Howard City MI
- Attack and Axys
Just press them on,
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
^^^^ yup just press them on, no need to lube them.
Supa Dexta
Little shot of WD makes it a touch easier, but its not needed. They actually do get a touch hot when you do it dry.
Use a scribe line to make your measurements - pen/pencil will wipe right off.
Mark the center between the 2 inner drivers, measure center of track window to track window
and then subtract half the width of the new driver from half the window/window measurement and thats it! (the measurements are also poster around different threads depending what drivers you use)
Pretty straight forward.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
How much force does is required to press on the drivers? I have a small arbor press and was thinking of doing it myself but then I can also send the shaft out to performance shop and have it done there.. Just trying to get an idea..
Supa Dexta
It takes quite a bit, but any half #*$&@ actual press should be able to get them.
I was helping a buddy do his polaris a couple weeks back and we tried to cut corners on adjusting the press - so pressing against the floor rather then the table - it was lifting the press and the 2 of us off the ground +600 lbs? without budging the drivers. haha
toyota4runner
- Jan 23, 2012
- Manitoba
- '09 FX Nytro
I was thinking about heating up the drivers in hot water to expand them a bit and put the shaft in the snow for install might make the job a little easier. Won't hurt to try anyway and a little WD never hurt anyone. I'll try your measure off center technique, should work out fine
