Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
I haven't rode it yet. No snow here. I havn't read any negative comments on it. I would assum that the suppliers have tested it. I'll let you know if and when we get some snow. If I have issues I guess a ZX-2 will be next on my list.
yamagradall
thanks for the imput i was leaning toward the muffin works set up next is the track 1.5 ripsaw? or cobra?what do you think what have tried!!
Phazernut
- Nov 2, 2007
- 04 Viper ER.
96 V-Max 4
Based on what I have read here if those are your choices then the cobra hands down. Ripsaw sucks off trail and I assume if you are going 144 then you will be off trail sometimes. If you go any bigger than 1.5 you will have to remove your tunnel protectors.
yamadog07
can you run a 1.5" track with studs & still have clearence ?
(i thiought it was an issue)
if you extend a 121 to 136 & run a 1.25" track with studs, is there any issues with studs rubbing or maybe hitting my rear cooler ?
would like to hear some more feedback on the 144 extension. i also thought there were hyfax wear issues. for those that have extended to 144" how is the cornering & overall set-up ?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
yamadog07 said:can you run a 1.5" track with studs & still have clearence ?
With the way I did my setup, my hyfax are in good shape and for cornering not to bad a little more work but not a lot.
