Vmax4
- Apr 18, 2003
- Orondo, WA
- 2010 FXNytro MTX 162 SE with a 270 hp MCX Turbo and assorted goodies!
OK, I have a 2007 Phazer FX. I moved out west and am now in mountain country. I would like to turn this sled into the 144x14x2 mtn light.
I was thinking I would get the rail extensions from TRACKSUSA, and order the track from Yamaha (since you can't get a 14 inch wide 2 inch paddle anywhere else), but will need to do something about a tunnel extension. Anyone making one?
Also, what else am I going to need to make the switch????
Thanks,
Steve
Thanks,
Steve
teerex
Yes you will need to extend the tunnel. Just take a look at my pics in the Freeride track opinions thread. I have the 136" track.
Maybe it would be better to just switch to a mountan lite instead
http://www.ty4stroke.com/viewtopic.php? ... c&start=45
http://www.ty4stroke.com/viewtopic.php? ... c&start=60
http://www.ty4stroke.com/viewtopic.php? ... c&start=90
rfabro
Buy the OEM mtn lite parts for the tunnel.
Vmax4
- Apr 18, 2003
- Orondo, WA
The MTN Light tunnel is all one pices, atleast the center section, so you can not really buy it as a kit? I can get the reinforcement part that goes on top, but not the center section. Will have to make that one................... Unless some one has a kit already???
Also, are the front drivers the same? Clutches the same? I know the gearing is different..........
Phazed-Coug
mtn light uses 8 tooth, other models use 9 tooth
