Had my 2010 Vector apart to install grease fitting in the steering bushing and check that all joints had lube. Had gas tank off, battery out , light pod off, put everything back together, turn key on an the warning indicator light, fuel meter indicator, fuel meter segments are flashing!! Checked all wires were put back together right . Any know hot to reset this?
Len Todd
When everything is right, it will reset itself.
Do you have enough fuel in the tank to shut off the low fuel warning?
Yes , tank is all most full. I will recheck everything again! Thanks
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Definitely check all electrical connections and not just the ones that you disconnected. You may have inadvertantly severed a connection by pulling on some wiring.
Maybe disconnect the battery for a minute or so and hook it back up and see if that helps.
Is there any code flashing on the speedo?
- 8K
