nbsledder
Does anyone on here know what could be wrong with my sled? The warning light keeps coming on and flashing seven or eight times and the fuel gauge says empty but it's got almost a half a tank in it......also the speedo sometimes is reading but the track hasn't even moved?
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Bad ground, have you checked/cleaned your battery cables?
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
Did you have your handlebars off?
nbsledder
Had them off a couple of years ago to put a 1 inch riser in.
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
nbsledder said:Had them off a couple of years ago to put a 1 inch riser in.
Couple of years ago? It's not what I was thinking then.
rage man
unno but defentally somthing electrical
LazyBastard
Next time you start a thread, it might be helpful to put the SUBJECT in the Subject line.
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
Fixed.
Len Todd
If you had a bad ground at the battery connection, it seems that you would have noticed trouble, at least intermittantly, with the starter.
I do not have Tech or Operator Manual with me. But, have you looked in your Operator Manual to see what the seven or eight flashes, whichever it actually is, = in the trouble shooting codes? It could be telling you you have a short or open in the wiring or at a connection point in the indicated circuit. Could the riser have caused a pull on a wire and broke it?
- 8K
