megasunomi
how do you reset the warning lights? I have a code 3 flashing and not sur eif it can be reset some how or what?
madforR1s
I don't know about sleds, but with bikes the warning codes reset themselves after you fix the problem and the computer turns on (runs a diagnostic check)with the first start up. Try fixing the problem and then disconnecting the battery for a couple of minutes. This should reset the computer. If the warning persists, then maybe the problem persists.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
What does a code 3 mean? Did you do the repair for it? I'd say that disconnecting the battery for a few minutes should clear the trouble code though.
megasunomi
DISCONNECTING THE BATTERY DOES NOT FIX THIS.
I had a bad left side hand warmer, this caused an imbalance in the circuit and would not complete the circuit. A new grip fixed it.
Convert
- Apr 14, 2003
- Lakeville & Nevis, MinNoSnowta
My handwarmers were hooked up wrong and caused the same error code, once fixed the warning light went away by itself no reset required. Do the handwarmers work now?
megasunomi
Yes the lights are out and the right warmer works, the left will not warmup when all is connected properly.
