Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Check your anti freeze mixure!
I was reading about a few guys blowing the fuse to the DC outlet where I tapped my face shield and didn't want to find out on a cold dark nite that mine had blown also. So I relocated the connection to the other side of the sled and tapped into the power for the reverse beeper. I decided to check the coolant seeing that I had everything apart. I sucked a gulp into my checker and all 6 balls imediately rose to the top. Right on the checker it says 6 balls are dangerous
This will result in poor cooling, water it down
![Die :die :die](/styles/default/xenforo/smilies/die.gif)
![Censored #$%&* #$%&*](/styles/default/xenforo/smilies/censored.gif)
dirkdiggler
Suspended
I was baout to post the same thing. Yamaha used strait coolant with zero water. I just got done draining my cooling system and replaced it with "Engine Ice". It is a complete cooling system replacment it. You don't add water or anti freeze. It works awesome!!!
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Hey mighty,do you know why anyone would blow the 12 volt plug fuse if they did not mess with anything,now i am not saying i have,but yesterday my gps went dead on me and it said low batteries,and it was pluged in,i thought that as long as it got juice from a power source it would work,and after looking at the power cord pistol at the power light,i dont think it was on,is the fuse easy to check,and is it a standard fuse?? Thanks PeteMightyWarrior said:Check your anti freeze mixure!
I was reading about a few guys blowing the fuse to the DC outlet where I tapped my face shield and didn't want to find out on a cold dark nite that mine had blown also. So I relocated the connection to the other side of the sled and tapped into the power for the reverse beeper. I decided to check the coolant seeing that I had everything apart. I sucked a gulp into my checker and all 6 balls imediately rose to the top. Right on the checker it says 6 balls are dangerous![]()
This will result in poor cooling, water it down![]()
![Rockon :Rockon: :Rockon:](/styles/default/xenforo/smilies/rockon.gif)
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
Fuse block is on the right hand side above the brake caliper. Only a 3 amp fuse for the dc outlet, not sure why. I noticed that there is a spare in there. I myself would use a higher amp fuse.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Why would Yamaha only run straight antifreeze?
dirkdiggler
Suspended
Rotax! said:Why would Yamaha only run straight antifreeze?
Yamaha has been doing this for years. The only reason Guys check it now is they know Yamaha does it.
SPEED
Dirk , This Engine Ice you speak of , Is it readily available or is it something I would have to order?
LooseCannon
Thats a darn good question. You would think that Yamaha would have the resources needed to best determine how much anti-freeze is required for their equipment. Especially after doing it for years, I would asume Yamaha has chosen the proper amount.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
I have no idea why they do it but it's Bull$hit. After 3 years of this somebodies head should roll over there ![Die :die :die](/styles/default/xenforo/smilies/die.gif)
Silverbullet
Heck ..look at the money they could save if they mixed it 50-50 :!: :!: They must have a reason for it ![Beer :beer: :beer:](/styles/default/xenforo/smilies/beer.gif)
welterracer
Doest the sleds come DRY??
I believe the dealers do the 4 Hr setup and fill all the fluids...
On a side note: MY was 100 percent antifreeze and i drained some and added water and watter wetter!
NY_SXR700
- Dec 30, 2003
- Webster, NY
- www.sohonetworksny.com
- 2001 SXR700
2006 Apex-GT
Even more strange, I put a hole in my GT's front exchanger and when I was power washing my sled to take it to get welded, I noticed pink all over in the snow. I figured Dex-Cool like in my new truck. I get to the welders and after welding up the front exchanger I remove the fluid cap for the coolant to pressure test the new weld. The cap is all GREEN!! What was all the pink stuff in my trailer that I thought was Dex-Cool. That was VERY odd. Doug
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
Shock fluid??NY_SXR700 said:What was all the pink stuff in my trailer that I thought was Dex-Cool.
