WesG
Gaskets
I would like a couple gasktes as well as a couple 25 series gaskets. Thanks,
Wes
Wes
JIM
i confirned the orders today and they will be cut monday and shipped to me on tuesday. I should see them by friday.
WesG
sounds good
just let me know how you want to be payed
Wes
Wes
WesG
Prep for the gaskets?
So you just belt sand the surface flat, check it on a glass and seal it up with this gasket? Any other special prep needed?
Wes
Wes
JIM
I took it to a motor shop in town that builds alot of them and they had a sweet 15 inch wide belt sander. The hard part bout sanding it is the pipe bend is soo close the end of the flange that it has to be sanded perpendicularly to the header. So what we found is that you dont apply alof of force, just let it sit flat and it do its job. I did bend the outer tabs a bit flat so that there wasnt material taken from the likely areas that warped, the two outer lowercorners. Junior says that this gasket will seal up to a 1/16 of an inch .060 of an inch. This gaskett has a 50% squish rate. It comes 1/8th thick. So there is no need to sand the header perfect.
WesG
Sounds good!
Sounds good. I picked up some of the locking header bolts from Paul @ impulse to hold that sucker to the head as well.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
JIM said:I took it to a motor shop in town that builds alot of them and they had a sweet 15 inch wide belt sander. The hard part bout sanding it is the pipe bend is soo close the end of the flange that it has to be sanded perpendicularly to the header. So what we found is that you dont apply alof of force, just let it sit flat and it do its job. I did bend the outer tabs a bit flat so that there wasnt material taken from the likely areas that warped, the two outer lowercorners. Junior says that this gasket will seal up to a 1/16 of an inch .060 of an inch. This gaskett has a 50% squish rate. It comes 1/8th thick. So there is no need to sand the header perfect.
Looks good!
WesG
Mid-season update
Gaskets are working flawlessly so far. I have pulled my turbo off twice and reused the square gasket, Not the long header one but the turbo gasket. Even after a couple squishes, the gasket is much thicker than the metal one I had before. Have not noticed any header leaks and with Pauls locking bolts no loose header. If you want to eliminate potential problems, I would do both the locking bolts and the gaskets. They are both relatively cheap to do.
Wes
Wes
srxguy
Is there a website for the locking bolts?
TT
srxguy
thanks
