Which is best, What is the consenus, studding center belt only or the outter belt as well.
If any one has studded the center belt only please provide info for center belt pattern recommendations for a 144 pattern.
I have a woody's templete for the long track for studding the center and outer belts.
welterracer
Because of the longer track , if you use 162 studs in a 3x3x3 pattern it is equal to 144 studs in a 121 track
I used a v pattern!!
