I updated the sway bar on my 05 RX warrior. I installed the 13mm bar from Pioneer Performance - Everything seemed to go as planned....How much side to side "play" should there be? My bar is flush with the outside of the link on both sides...and there is about 1/4-3/8" play side to side.
Thoughts?
Thoughts?
ZapeX2
My pioneer has about 1/8 to 1/4 play... My stock one had more than that. I would say yours is probably fine, I'm no expert though. If you are concerned, contact Pioneer for their specs...
Enjoy....
Enjoy....
that is normal.
LazyBastard
Squeeze the links in further before you tighten them.
LazyBastard said:Squeeze the links in further before you tighten them.
So - the ends of the bar will be proud of the links...? As a result, there should be almost no play side to side when I am done - correct?
Thanks,
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Thats correct I took the slop out by having my wife hold one side tight to the bulkhead and then me pushing the link tight to the bulk head on the other side. Works like a champ and you get to spend time with your wife LOL
LazyBastard
Or for those whose arms are more than 6 inches long, you can just reach over and hold the other side yourself...
rx1ryda989
- Feb 7, 2007
Yea wifes and gf's are sure fun to work on sleds with kinger. lol
kinger
- Jan 17, 2005
- Clear Lake, IA
LazyBastard said:Or for those whose arms are more than 6 inches long, you can just reach over and hold the other side yourself...![]()
What do you got 3 arms there LB! LOL One to apply pressure from left, one to apply pressure from the right, and one to tighten said bolt to keep slop out.
LazyBastard
Yeah, that third arm really comes in handy
