Warrior Upgrades
Ripsaw works great on the trails, not that good in the deep.
Other upgrades include skis (or at least more / better carbides) and maybe a thicker swaybar, 12 or 13mm. Stiffer front springs not a bad idea either, I went with the Ohlins shocks instead.
Taller screen for cold weather, and I've put on bar risers.
Leave the Ripsaw alone, awesome track! Remove the rivet in the tip of the primary weights and ride.
He did not say what year his sled was. I was assuming it was a 03 with the finger track.
IMO the Ripsaw is OK at best. Much better 1.25 tracks out there that will out perform it. I used to have a 9818 SnoCross track and it performs much better IMO than the Ripsaw.
Ripsaw is a "all terrain" ttrack. Good at most stuff,master of none.
I'm running a Cat sno pro 1.375 136 on mine personally.
Drilling the tip weight will net some RPM, but the best result is swappingout with some slutching that works.
The stock weights are VERY VERY conservative as far as profile goes.
Great results here with Dalton weights.
