Trig 313
I have a question about the weight tranfer rod. Mine is set at max and I would like to set it so I do not have so much lift with I punch the throttle. I have tried to turn the nut but it dose not budge. Any idea what tool I should use ect.... Any help would be great....
Len Todd
Someone may have put some locktite on it. ? Maybe a little heat directly on the nut will help. But do this sparingly. Stick to the nut.
Otherwise, try some real penetrating oil. I say real, cause a lot of folks think WD-40 is penetrating oil. It is not. Let the real penetrating oil soak in overnight.
If you are rounding off the hut already, you may want to consider going to a pipe wrench and just replacing the nut after you get it off.
