Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
I'm not sure the weight savings is worth it. I rode a 141 for years and the ride is horrendous. I tried all spring combos on coilover shocks, did Fox floats (revalved, added reservoirs etc), also did the Hygear linkage kit etc. I think I would sooner a sled weigh 100 lbs more and have a nicer ride. I guess it depends on what your goals are. I usually carry gas etc so weight savings arent a priority to me.
When I say horrendous ride, I mean on any trail with bumps, smooth trails was fine of course!
But I do agree its by far the lightest skid out there. You can make it lighter/stronger by going to Ice age rails too.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Thanks for the info. I'm more of a speed runner and when the trails are rough I go home.I'm not sure the weight savings is worth it. I rode a 141 for years and the ride is horrendous. I tried all spring combos on coilover shocks, did Fox floats (revalved, added reservoirs etc), also did the Hygear linkage kit etc. I think I would sooner a sled weigh 100 lbs more and have a nicer ride. I guess it depends on what your goals are. I usually carry gas etc so weight savings arent a priority to me.
TugHillWinder
- Sep 16, 2023
Can the XTX rear arm and Float shock be retrofitted into the "standard" SideWinder rear suspension? Or, must one acquire an entire XTX rear skid if wanting to try for the above-mentioned reason of weight reduction?
DMCTurbo
- Nov 12, 2005
You need the whole skid.Can the XTX rear arm and Float shock be retrofitted into the "standard" SideWinder rear suspension? Or, must one acquire an entire XTX rear skid if wanting to try for the above-mentioned reason of weight reduction?
You are right. I owned one in 2018. It bottoms far too easily(and I'm light) and the skis are always in the air.I'm not sure the weight savings is worth it. I rode a 141 for years and the ride is horrendous. I tried all spring combos on coilover shocks, did Fox floats (revalved, added reservoirs etc), also did the Hygear linkage kit etc. I think I would sooner a sled weigh 100 lbs more and have a nicer ride. I guess it depends on what your goals are. I usually carry gas etc so weight savings arent a priority to me.
However, it is lighter.
DMCTurbo
- Nov 12, 2005
I had a 141 on my 16 Viper with Fox 3 Evol shocks on all 4 and I thought it rode incredible.You are right. I owned one in 2018. It bottoms far too easily(and I'm light) and the skis are always in the air.
My 2019 X-TX LE 141 has the full QS3 shock package and it rides pretty good to the point I don't fall behind anyone in our group on the drifted open lakes even when riding with the highly overhyped Doo R motion guys.
