weight transfer
bigdaddyjak
MI
just got an 04 RX 1 with M10. runs great rides like sh!t ! it is all over the place on the trails, it just seems like a bear to control. From what I understand and have read(i have been reading on here every day about it) it sounds as if i need to transfer weight off from the skis, as too much weight on the skiis is causing it to dart all over the trail, is this correct? what is the easiest way to do this ? thanks
Don't know where your sled is at, but I would let the limiter straps out all the way, then test ride to see if you can leave them that way. Maybe take the necessary tools to adjust them with you so you can try a couple different settings?
