yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
Here goes the 2010 sled build, a 2008 nytro rtx without boost (boosted one is in the shop)
I want this sled to be a good drag racer for the few races i can attend and more importantly a good jumping machine with the ability to play in the hills.... Here is the list of parts going on it to date and like the title says what am i missing???
9 tooth avid drivers
1.75 snocross track
19 tooth top gear
blue brown blue or white white white spring
float x shocks
re-valve rear shocks (Diamondhead yamaha)
k&n intake (Thanks allen)
Pc3 again thanks to allen
mpi pipe No mid pipe yet
cr10 plugs
headlight delete kit w/ vent
Articfx snowflake yellow black
slydog skis yellow w/6"
sledsolutions lightweight seat
ytz10 battery
tether kit (OFT racing) sweet sweet kit!
and of course being an o8 front clip plates and gussets
I hope to knock off 15 pounds and maybe gain 5-10 hp?
I want this sled to be a good drag racer for the few races i can attend and more importantly a good jumping machine with the ability to play in the hills.... Here is the list of parts going on it to date and like the title says what am i missing???9 tooth avid drivers
1.75 snocross track
19 tooth top gear
float x shocks
cr10 plugs
ytz10 battery
Zakre
I forget who said it but the best parts are the ones left in your garage.
yukon yamaha
- Jan 30, 2008
hahah this could be true
sleddingfarmer
No mid pipe yet...You gotta get a header pipe
yukon yamaha
- Jan 30, 2008
No header pipe i was looking at the excell header but i am not sure yet...i would like to see if the mpi pipe would fit the ecxell header.... i love the full system but i an not feeling it for this project.
I have only seen one mbrp header and meh nothing special and the excell is kinda $, but that is something i should keep in mind, the pipe should give it some more hp.... i hope
Alatalo
- Jan 11, 2005
How about 2.86" pitch drivers and track (to get a bigger selection of proper snocross tracks)...?
yukon yamaha
- Jan 30, 2008
Yes i did also think of that but I have run this track on my turbo and loved the hook up and it lasted a full year with no missing lugs! I go through at least one track a year and this one held together so i am goin to see how it does on a stock machine.....
