JRD69
- Oct 9, 2004
Thats what I talked to Turtle about today he seems to believe this will solve alot of the problem. Where did you purchase fitting I plan on trying this in conjunction with evac kit from Bob at L/P oil blow by should no longer be an issue!!! BTW are you going into stock hole or tapping a new hole???
dumbass
I've got it comming from Alpine Motorsports, 250-804-4334, its aluminum with a 1/2" connection, and it does thread into the stock hole.
Buckeye
- Lakes Region, NH
dumbass said:Sorry about "back into the top of the motor" thing, I did mean into the valve cover. Have any of you tried this? Apparently some of the front mounts drain their oil from the turbo into the top of the valve cover. I've got a fitting comming that will screw into the plug on top of the valve cover. I'm going to try and route the breather into this and see what happens. Will there be an problems with not having an actual "atmospheric" vent?
Yes there would be a huge problem. If I understand you. You are going to take the case breather hose and vent it to the valve cover? That would be the same as plugging it. KABOOM! If anything you want to vent both holes to the atmosphere or an external breather device. I will be venting mine 3 ways to the Lightning Pro box. I believe with that much venting, there won't be enough pressure to push the oil up the vents out of the case. This basically will be tripling the venting capacity. Blow into a hose with one hole. You get pressure on the other end. Now put 3 holes into it and blow. Less pressure. Same principle.
One more thing. This is also a boost pressure related problem. As the pressure increases, so does the case pressure and the probability of oil coming out the breather. I believe you could run all day at 8 #'s and speeds less than 80 mph and not have a problem. Crank up the boost and do some sustained full throttle runs and here comes the oil.
spray25
I beleive that LP uses the exsisting line, the valve cover cap hole, and a tee in the line going to the oil tank. If they do in fact use the line to the oil tank the be aware that if you should lay the sled on it's side (especially the left) or roll it over there is a high likelyhood that oil will leak out. Unfortunately us mountain guys do this to often :shock:
Uncle Buck, You currently have a vent in the oil cap. Did this help at all? Do you think two 1/2" lines out of 1/2" holes in the valve cover would be adequite?
Buckeye
- Lakes Region, NH
The line I have out of the valve cover is too small, although any additional venting is a plus. Two 1/2" lines would be good, but bigger would be better.
You are right about the way LP vents their's. Fortunately, I don't lay ny sled on it's side. You could however tap more holes into the block or valve cover to add vents.
spray25
Buckeye said:You could however tap more holes into the block or valve cover to add vents.
That's exactly what I am thinking. The valve cover is very easy to remove for tapping. I might be able to find something larger than 1/2, but I live in the boonies.
Buckeye
- Lakes Region, NH
You could use a brass bulkhead fitting used in boats, They come in a variety of sizes. The fitting for the existing holes is 18 mm I believe.
JRD69
- Oct 9, 2004
Chip I think he is referring to draining oil directly from turbo into valve cover and blocking hole in case-- Can I drain turbo into valve cover and run vent line into existing hole in case???
JRD69
- Oct 9, 2004
Where are you guys finding those fittings??
spray25
I just ordered some custom fittings so that I can put two 3/4 vents in the valve cover.
It was done as a favor to me, but if there was enough demand he might make up some more.
I will post pics next week when I get it all done.
Buckeye
- Lakes Region, NH
JRD69 said:Yes there would be a huge problem. If I understand you. You are going to take the case breather hose and vent it to the valve cover? That would be the same as plugging it. KABOOM!
Yes, that may be our next step.
The drain fitting is available from McXpress or you could get a 5/8" inlet that will screw into the existing hole in the valve cover from LP.
Buckeye
- Lakes Region, NH
dumbass said:I've got a fitting comming that will screw into the plug on top of the valve cover. I'm going to try and route the breather into this and see what happens. Will there be an problems with not having an actual "atmospheric" vent?
Looks to me he is saying running the breather to the valve cover?
dumbass
OK, this is all making more sense, I may have been missunderstanding the information I was getting. I WAS going to route the breather into the valve cover but sounds like that will cause more serious problems. I think I'll wait and see what is really going to work the best. Thanks for the help.
JRD69
- Oct 9, 2004
AHHHHHHHHHHHH got it
So here we are
1. Drain turbo directly in valve cover tapping new hole with new fitting
2. Use L/P evac kit to vent case and send back into oil tank & stock hole in valve cover..
3. Plug hole in case where turbo is draining now
4. let er ripppppppppppppp
p.s. Buckeye did you get E-mail from Bob L/P box looks awsome should work great!!! I'll keep you updated
So here we are
