yamagone
- Dec 17, 2008
- Essex, Ont. Canada.
- 18' Sidewinder
Anyone have performance plans for their sled this summer? After one season I have the boost bug. Currently using Hurricane's Hindle exhaust and Super Tuner weights which worked well but plan on a 240R re-flash for next season as well as a JT 4th wheel kit.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Going to the new 1" SRX track with 144 1.5 Studboy lake racers and 22-37 gearing for next year.
Some of these are already completed but summer plans are as follows for my ltx le
1.) Storm 150 track
2.) Woodys gold digger studs
3.) 24/50 gearing from 21/41
4.) TD gap flasher with max 16 for stock muffler and powertrail for aftermarket muffler. Maybe another tune or 2 in the mix
5.) Blue front nose cone (modified to fit the barn of parts intercooler guard
6.) Skinz shorty adjustable brake lever
7.) Painting front bumper white (srx color ques)
8.) Mess free oil drain hose
9.) Right lower side panel rivnut install for easy removal
10.) Routine maintenance and inspection
1.) Storm 150 track
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
Every year I tell myself that enough is enough and the sled is set up just the way I like it, and then someone posts a thread like this one
I've tried, but every year I end up looking just like this guy....
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Oh, you know, the same old same old . . .
Brand new '18 LTX is getting (being moved over from '17 RTX)
CoPiTrail - data logging and high speed gps, antilag
TD Flash bundle EcoTrail, PowerTrail, Max17, MaxSpool17, Maxspool20
GAP 02 sensor
TD CAI
TD 3 bar MAP
3" Sandale muffler (with TD stock Mod as alternate)
Yamaha sport mid windshield and side view mirrors
Excel charge tubes
TS Blow off valve
OSP intake
Dalton clutching, broth springs, helix and weights
Prevost/TD aluminum clutch guard
Front panel venting for clutch
Primary shaft being milled 2mm to reduce offset
Thundershift 14.8 Thunder Rollers
Thundershift Dorolon secondary rollers
Thundershift Glidewashers
TPI 911 primary cover
TPI HH clutching should I choose
Camso Storm, 144 Golddiggers, CB Performance template and pattern
STM full length tunnel protectors
Racewerx coupler adjuster
J&T 4 Stealth 4 wheel kit
RR upper cross shaft and steel lower shock mount
Curve XS skis and Slim Jims
Blown Concepts custom Wrap
Axis custom built shocks for all 4
BOP skidplate
BOP Japanese throttle level
Powermadd Adjustable riser
Blue LED undercarriage lights
Yamaha tunnel bag
Right and left lower side panel rivnut install for easy removal
mess free oil drain hose from Haauck
flux capacitor and weapons grade plutonium
Rollover valve mod
New deluxe cover
There's probably more . . .
GAP 02 sensor
TD CAI
TD 3 bar MAP
Excel charge tubes
TS Blow off valve
OSP intake
BOP skidplate
Yamaha tunnel bag
Rollover valve mod
New deluxe cover
Finesy
- Apr 18, 2017
- Manitouwadge
- 2018 Sidewinder RTX 50th Anniversary
2017 Sidewinder LTX SE
My summer mod plans? To sell atleast one of the two that I have. Don’t matter which one, but I suspect the 18 RTX 50th that my wife drove last winter will sell the easiest. Both sleds are on their original belts and the only issue I experienced with either was the oil reservoir seal failing on the 18 RTX. We got 6 feet of snow up here this winter and it was too much for these heavy 4 strokes. I’ve Spring Ordered a 19 Assault 850. The Yamaha dealer and Yamaha Canada pissed me off too much to forgive and forget. Oh ya, I also just bought a new 18 Honda Pioneer LE side by side. I used to own two Yamaha Grizzly ATVs. “Karmas a Bitch, isn’t it".....
DMCTurbo
- Nov 12, 2005
See ya! I’m tired of listening to you whine like a little girl.
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
My summer list includes a oil change and replacing a few worn out steering bushings and a handwarm my dealer warranted for me. Plus a damaged aluminum belly pan that somehow got ripped trail riding? Send out my shocks for Cannondale to refresh and thats it. I love my current set up no mods needed this year. I'm looking forward to riding with all the TY friends and family next season.
fullshift
- Mar 8, 2004
- Manitoba
- 2017 ZR9000 Limited 129
Ordered my hurricane tune bundle and trail kit
. I am going to gear up to 21/41 so if anyone has a good used B/W chain gear set I am interested. Going to try to fabricate a CAI like Rockerdan. Speedwerx vent kit along with my own venting. Changing my drivers and track to a 1.5 ripsaw 1 -2.52 pitch, every 3rd window clipped, a rear 4 wheel kit, with vespel siders. I love my sled so hoping to make it even better.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Ordered my hurricane tune bundle and trail kit. I am going to gear up to 21/41 so if anyone has a good used B/W chain gear set I am interested. Going to try to fabricate a CAI like Rockerdan. Speedwerx vent kit along with my own venting. Changing my drivers and track to a 1.5 ripsaw 1 -2.52 pitch, every 3rd window clipped, a rear 4 wheel kit, with vespel siders. I love my sled so hoping to make it even better.
If your going to change tracks, get it fully clipped.
fullshift
- Mar 8, 2004
- Manitoba
If your going to change tracks, get it fully clipped.[/QUOTE] I already had the track on shelf bought for another sled but never put it on it is a AC track 2602-835 so I guess I am also getting some clips and an clip tool.
